Hello all,
I follwed the instructions to erase the eMMC and boot from SD but the R5S is not booting. I got the dump from the serial port:
DR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21
In
LP4/4x derate en, other dram:1x trefi
ddrconfig:0
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 24ps, dqs1: -48ps, dqs2: -48ps, dqs3: -144ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x62
rx vref: 30.4%
tx vref: 36.0%
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
rx vref: 30.4%
tx vref: 38.0%
change to: 780MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
rx vref: 14.6%
tx vref: 36.0%
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x2b
rx vref: 15.6%
tx vref: 18.8%
cs 0:
the read training result:
DQS0:0x27, DQS1:0x2e, DQS2:0x2e, DQS3:0x2c,
min : 0x9 0xa 0xd 0xa 0x2 0x5 0x8 0x3 , 0xa 0x9 0x1 0x3 0xf 0xb 0xc 0x9 ,
0x10 0xf 0x8 0x9 0x3 0x0 0x3 0x8 , 0x9 0x5 0x5 0x2 0xd 0xe 0xa 0xf ,
mid :0x22 0x21 0x24 0x22 0x1a 0x1c 0x20 0x1c ,0x23 0x23 0x1a 0x1b 0x26 0x24 0x24 0x23 ,
0x2a 0x29 0x21 0x22 0x1b 0x1a 0x1b 0x1f ,0x22 0x1e 0x1f 0x1b 0x26 0x28 0x24 0x27 ,
max :0x3b 0x39 0x3c 0x3b 0x33 0x34 0x39 0x35 ,0x3d 0x3d 0x33 0x33 0x3e 0x3d 0x3d 0x3d ,
0x44 0x43 0x3a 0x3b 0x34 0x34 0x33 0x36 ,0x3c 0x38 0x39 0x34 0x40 0x42 0x3f 0x3f ,
range:0x32 0x2f 0x2f 0x31 0x31 0x2f 0x31 0x32 ,0x33 0x34 0x32 0x30 0x2f 0x32 0x31 0x34 ,
0x34 0x34 0x32 0x32 0x31 0x34 0x30 0x2e ,0x33 0x33 0x34 0x32 0x33 0x34 0x35 0x30 ,
the write training result:
DQS0:0x2f, DQS1:0x22, DQS2:0x22, DQS3:0xf,
min :0x6f 0x71 0x73 0x72 0x68 0x6a 0x6f 0x6b 0x6d ,0x5c 0x5b 0x54 0x55 0x61 0x5c 0x5e 0x5c 0x59 ,
0x5c 0x5c 0x56 0x55 0x50 0x4e 0x4f 0x54 0x57 ,0x48 0x43 0x43 0x3e 0x48 0x4a 0x46 0x4a 0x44 ,
mid :0x89 0x8a 0x8d 0x8c 0x81 0x83 0x88 0x85 0x86 ,0x76 0x75 0x6d 0x6e 0x7a 0x75 0x77 0x75 0x72 ,
0x77 0x77 0x70 0x70 0x69 0x67 0x69 0x6e 0x70 ,0x60 0x5d 0x5b 0x57 0x63 0x65 0x60 0x64 0x5e ,
max :0xa4 0xa4 0xa7 0xa7 0x9a 0x9d 0xa2 0xa0 0xa0 ,0x90 0x90 0x87 0x87 0x93 0x8f 0x91 0x8f 0x8c ,
0x93 0x93 0x8a 0x8b 0x83 0x81 0x84 0x88 0x8a ,0x79 0x77 0x74 0x70 0x7f 0x81 0x7a 0x7f 0x78 ,
range:0x35 0x33 0x34 0x35 0x32 0x33 0x33 0x35 0x33 ,0x34 0x35 0x33 0x32 0x32 0x33 0x33 0x33 0x33 ,
0x37 0x37 0x34 0x36 0x33 0x33 0x35 0x34 0x33 ,0x31 0x34 0x31 0x32 0x37 0x37 0x34 0x35 0x34 ,
CA Training result:
cs:0 min :0x3c 0x3a 0x41 0x3a 0x43 0x39 0x43 ,0x41 0x3d 0x43 0x40 0x43 0x3b 0x48 ,
cs:0 mid :0x79 0x7a 0x7d 0x7a 0x7d 0x79 0x70 ,0x7e 0x7d 0x7f 0x7f 0x7e 0x7b 0x76 ,
cs:0 max :0xb7 0xba 0xba 0xba 0xb8 0xba 0x9d ,0xbb 0xbd 0xbc 0xbe 0xba 0xbb 0xa4 ,
cs:0 range:0x7b 0x80 0x79 0x80 0x75 0x81 0x5a ,0x7a 0x80 0x79 0x7e 0x77 0x80 0x5c ,
out
U-Boot SPL 2024.10-OpenWrt-r29087-d9c5716d1d (Dec 17 2025 - 21:08:22 +0000)
Trying to boot from MMC1
mmc_load_image_raw_sector: mmc block read error
Trying to boot from MMC2
## Checking hash(es) for config conf ... OK
## Checking hash(es) for Image atf-1 ... sha256+ OK
## Checking hash(es) for Image uboot ... sha256+ OK
## Checking hash(es) for Image fdt ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
## Checking hash(es) for Image atf-3 ... sha256+ OK
## Checking hash(es) for Image atf-4 ... sha256+ OK
## Checking hash(es) for Image atf-5 ... sha256+ OK
## Checking hash(es) for Image atf-6 ... sha256+ OK
## Checking hash(es) for Image optee ... sha256+ OK <<<<======== it's hangging here!
Any ideas? Can anyone please shed some light?
Thank you !
