Going nuts with Docker
After finally getting my R5S running from NVMe, I've been having much better success with Docker. I thought I'd share some of my config. My R5S is running off an internal 500GB NVMe, a 128GB would be adequate. I've setup a 14GB swap partition, but I've never seen its use go over 20%, so I imagine a 4GB swap might be adequate, but there doesn't seem to be any harm having a bigger one. The swap really helps when resources are stretched like when you index photos with Photoprism.
I'm running the following containers:
    nginx
    certbot
    watchtower
    qbittorrent
    homeassistant
    jellyfin
    photoprism
    mariadb
    adminer
    bookstack
Nginx acts as a reverse proxy, so I can have subdomains:
    mywebsite.com
    homeassistant.mywebsite.com
    jellyfin.mywebsite.com
    photoprism.mywebsite.com
    bookstack.mywebsite.com
I keep all my Docker volumes and media on an external USB3 NVMe. This means if you have to upgrade firmware wiping the internal NVMe, it's easy to pick up where you left off when redeploying the containers.
system overview
That's with all the containers running but not much load/traffic.
docker stats
Note: docker stats shows CPU usage per core, so it's 4x100% = 400%. Like when you index photos with Photoprism, the CPU usage might say something like 271%. And in the image above qBittorrent is using of 36.53 of 400%.
First thing I do is change the ports Luci runs on:
vi /etc/config/uhttpd
    8000
    8443
/etc/init.d/uhttpd restart
opkg update
opkg install docker-compose
docker-compose.yml
services:
  nginx:
    image: nginx:latest
    restart: unless-stopped
    user: "65536"
    environment:
      TZ: 'Australia/Melbourne'
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - /mnt/sda1/nginx/config:/etc/nginx/conf.d
      - /mnt/sda1/nginx/logs:/var/log/nginx
      - /mnt/sda1/nginx/nginx.conf:/etc/nginx/nginx.conf
      - /mnt/sda1/nginx/cache:/var/cache/nginx
      - /mnt/sda1/nginx/run:/var/run
      - /mnt/sda1/nginx/html:/usr/share/nginx/html
      - /etc/letsencrypt:/etc/letsencrypt:ro
    depends_on:
      - bookstack
      - homeassistant
      - jellyfin
      - photoprism
    networks:
      my-network:
        ipv4_address: 172.19.0.11
  certbot:
    image: certbot/certbot:latest
    user: "65536"
    environment:
    volumes:
      - /var/lib/letsencrypt:/var/lib/letsencrypt
      - /mnt/sda1/nginx/html:/var/www/certbot
    entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
    command: certonly --webroot --webroot-path=/var/www/certbot --email bob@mail.com -d mywebsite.com --agree-tos --no-eff-email
    networks:
      - my-network
  mariadb:
    image: mariadb:latest
    user: "65536"
    environment:
      MARIADB_ROOT_PASSWORD: "top_secret"
    volumes:
      - /mnt/sda1/mariadb/data:/var/lib/mysql
    networks:
      - my-network
  adminer:
    image: adminer:latest
    ports:
      - 8082:8080
    networks:
      - my-network
  qbittorrent:
    image: linuxserver/qbittorrent:latest
    user: "root"
    environment:
    ports:
      - "8080:8080"
      - "6881:6881"
      - "6881:6881/udp"
    volumes:
      - /mnt/sda1/qbittorrent/config:/config
      - /mnt/sda1/qbittorrent/downloads:/downloads
    networks:
      - my-network
  homeassistant:
    image: homeassistant/home-assistant:latest
    environment:
      - TZ=Australia/Melbourne
      - PUID=1000
      - PGID=1000
      - UMASK=007
      - PACKAGES=iputils
    volumes:
      - /mnt/sda1/homeassistant/config:/config
    networks:
      - my-network
  jellyfin:
    image: jellyfin/jellyfin:latest
    user: "65536"
    environment:
    volumes:
      - /mnt/sda1/jellyfin/config:/config
      - /mnt/sda1/jellyfin/cache:/cache
      - /mnt/sda1/media:/media
    networks:
      - my-network
  photoprism:
    image: photoprism/photoprism:latest
    ports:
      - 2342:2342
    environment:
      PHOTOPRISM_ADMIN_USER: "admin"
      PHOTOPRISM_ADMIN_PASSWORD: "top_secret"
      PHOTOPRISM_DATABASE_DRIVER: "mysql"
      PHOTOPRISM_DATABASE_SERVER: "mariadb:3306"
      PHOTOPRISM_DATABASE_NAME: "photoprism"
      PHOTOPRISM_DATABASE_USER: "photoprism"
      PHOTOPRISM_DATABASE_PASSWORD: "top_secret"
      PHOTOPRISM_SITE_URL: "https://photoprism.mywebsite.com/"
      PHOTOPRISM_ORIGINALS_LIMIT: 1000
      PHOTOPRISM_DEBUG: "false"
      PHOTOPRISM_INDEX_WORKERS: 1
      PHOTOPRISM_WORKERS: 1
    volumes:
      - "/mnt/sda1/photos:/photoprism/originals"
      - "/mnt/sda1/photoprism/import:/photoprism/import"
      - "/mnt/sda1/photoprism/storage:/photoprism/storage"
    depends_on:
      - mariadb
    networks:
      - my-network
  bookstack:
    image: linuxserver/bookstack:latest
    environment:
      - PUID=1000
      - PGID=1000
      - APP_URL=https://bookstack.mywebsite.com
      - DB_HOST=mariadb:3306
      - DB_DATABASE=bookstack
      - DB_USERNAME=bookstack
      - DB_PASSWORD='top_secret'
    volumes:
      - /mnt/sda1/bookstack/config:/config
      - /mnt/sda1/bookstack/uploads:/var/www/html/public/uploads
    depends_on:
      - mariadb
    ports:
      - "6875:80"
    networks:
      - my-network
  watchtower:
    image: containrrr/watchtower:latest
    environment:
    volumes:
      - "/var/run/docker.sock:/var/run/docker.sock"
    networks:
      - my-network
networks:
  my-network:
    driver: bridge
    ipam:
      config:
        - subnet: 172.19.0.0/16
nginx.conf
user  nginx;
worker_processes  1;
events {
    worker_connections 1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    # Upstream servers
    upstream bookstack {
        server bookstack:80;
    upstream homeassistant {
        server homeassistant:8123;
    upstream jellyfin {
        server jellyfin:8096;
    upstream photoprism {
        server photoprism:2342;
    server {
        listen 80;
        server_name *.mywebsite.com;
        # Redirect all HTTP traffic to HTTPS
        return 301 https://$host$request_uri;
    # HTTPS server block for Home Page
    server {
        listen 443 ssl;
        server_name mywebsite.com;
        # SSL/TLS configurations
        ssl_certificate /etc/letsencrypt/live/mywebsite.com/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/mywebsite.com/privkey.pem;
        location / {
            root /usr/share/nginx/html;
            index index.html;
    # HTTPS server block for BookStack
    server {
        listen 443 ssl;
        server_name bookstack.mywebsite.com;
        location / {
            proxy_pass http://bookstack;
            proxy_set_header Host $host;
            proxy_set_header X-Real-IP $remote_addr;
            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
            proxy_set_header X-Forwarded-Proto $scheme;
    # HTTPS server block for Home Assistant
    server {
        listen 443 ssl;
        server_name homeassistant.mywebsite.com;
        location / {
            proxy_pass http://homeassistant;
            proxy_set_header Upgrade $http_upgrade;
            proxy_set_header Connection "upgrade";
    # HTTPS server block for Jellyfin
    server {
        listen 443 ssl;
        server_name jellyfin.mywebsite.com;
        location / {
            proxy_pass http://jellyfin;
    # HTTPS server block for Photoprism
    server {
        listen 443 ssl;
        server_name photoprism.mywebsite.com;
        location / {
            proxy_pass http://photoprism;
MariaDB
-- Create BookStack database and user
CREATE DATABASE IF NOT EXISTS bookstack;
CREATE USER IF NOT EXISTS 'bookstack'@'%' IDENTIFIED BY 'top_secret';
GRANT ALL PRIVILEGES ON bookstack.* TO 'bookstack'@'%';
-- Create Photoprism database and user
CREATE DATABASE IF NOT EXISTS photoprism;
CREATE USER IF NOT EXISTS 'photoprism'@'%' IDENTIFIED BY 'top_secret';
GRANT ALL PRIVILEGES ON photoprism.* TO 'photoprism'@'%';
FLUSH PRIVILEGES;
ALTER DATABASE bookstack
    CHARACTER SET = 'utf8mb4'
    COLLATE = 'utf8mb4_unicode_ci';
ALTER DATABASE photoprism
Docker forwards various ports that don't show up in Luci:
Port forwarding
You can restrict access to the LAN by specifying the NanoPi IP address in the docker-compose.yml
  adminer:
    ports:
      - 10.0.0.1:8082:8080
    networks:
      - my-network
This can be useful if you don't want the login accessible over the internet. For example, if you don't need access over the internet or for services that don't support MFA.
