PTP - PHC not working
Posted: Fri Aug 04, 2023 11:17 pm
by Alberkan
Hi everyone,
I am trying to use the NanoPi R5C as a PTP device as its NIC Realtek RTL8125 has PTP support with hardware timestamping but I found a problem.
But first let me put you in context: enabling PTP in the NanoPi R5C is something not intuitive and probably somebody will find this useful.
  1. The driver which allows PTP hardware timestamping is the r8125 driver, a driver that you can install as a simple kernel module. But to enable PTP support you need to modify the Makefile and change the flags:
    ENABLE_PTP_SUPPORT =
    ENABLE_PTP_MASTER_MODE =
    If you want NanoPi as a master, put both to "y", if you want it as a PTP client, just the first one. I made some experiments and the driver can't work as master/client at the same time, so please choose one.
  2. Compile and install the module on the kernel. I would recommend to rebuild the entire kernel and create a personal Debian/Ubuntu img with the driver already installed.
  3. Check the correct version of the driver is running (modinfo), it has a ____-PTP on its name. Try:
    $ sudo ethtool -T eth0
    This will show if your ethernet interfaces have hardware timestamping support. If you have HW timestamping you can start to execute ptp4l as a client for example, but you will find something atypical: Path delay is negative.
In PTP the path delay SHOULDN'T BE NEGATIVE. Therefore, I checked the clock from the NIC, I mean: the oscillator (25MHz) that is connected to the Realtek RTL8125 and I tried to get the time from the clock. With phc_ctl you can check the time that is running on a registred clock of the system:
$ sudo phc_ctl /dev/ptp0 get
The result of this is the Unix time 0. The clock of the RTL8125 registered in the system is not running and the maths that PTP does goes wrong because of this. You can set a time with phc_ctl but immediately after, it will be restarted to 0.
This is something very unusual in PTP and the RTL8125 is quite often used in PTP devices like PC NICs, so I think that is something from the board firmware? Or something from the kernel that I am not doing well? I don't know, I would need some help.
Thank you!
Re: PTP - PHC not working
Posted: Sat Jan 03, 2026 5:02 pm
by muetzekoeln
More than two years later and I have similiar problems with NanoPi R76S. Quite unfortunate, with other brands of SBC there is PTP/PHC support, but not with the ones from FriendlyElec.
Someone is working on r8125 kernel driver and I hope there will be a solution soon.
Posted: Thu Jul 16, 2026 7:48 am
by lyraellington12
I haven't tested this on the R5C/R76S specifically, but if /dev/ptp0 always resets to Unix time 0, I'd also check whether the PHC is actually being initialized by the driver during probe. It might be worth comparing the vendor r8125 driver with the in-kernel r8169 implementation (especially the PTP initialization code) and checking dmesg for any PHC registration or firmware-related errors. Also, running ethtool -T and ptp4l -m with the latest kernel could help determine whether the issue is driver-specific or related to the board support package. Hopefully someone from FriendlyElec can clarify whether this is a hardware limitation or simply missing software support.
