Ubuntu to "7.0" pouces TFT LCD
Hello I was wondering if it would be possible to connect a nano pi neo air to this :?: : https://fr.aliexpress.com/item/32845300432.html
thank you in advance :D
That has an 8 bit SSD1963 so you'd need a driver and enough GPIO to use it.
From what I can see, the Neo Air is a headless design only. There is no interface for video that would be plug-in. You might be able to get a small form factor SPI interfaced LCD to work but you'll need to find drivers etc.
FA do have this display but screen size is much smaller.
https://www.friendlyarm.com/index.php?r ... uct_id=102
I had a similar project, thanks for your answer! I'll get a smaller display instead, and if it works (or doesn't), I'll describe my build on the forum.
thank you, that will help me
In total there are 25 users online :: 0 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 25 guests
