Fedora ARM in NanoPi M4B
Hi! I'm recently adquired a new Nanopi M4B board... I was playing with Friendlycore OS and with armbian too. But i'm curious, its possible (in some way) to install a Fedora ARM OS?
I was reading that is possible to install Fedora ARM into Raspberry Pi, but maybe is possible to compile the kernel or something like that to make it possible.
This is my first topic, thank you in advance for any information.
Regards!
I run Fedora on my NanoPC-T4. It didn't run out of the box and I had to change some configurations to meet my needs. For now, it boils down to rebuilding u-boot and the kernel for configuration modification. And rebuilding some other packages for early adoption.
IMHO it should also be feasible if your board has appropriate support in the main line.
