Power On Mode Select Jumper
Can't find info on this in the wiki - which jumper position does what? Thanks.
Looks like it comes from factory set to boot on return of power after a cut...
Yip. My T4 boots on applying power so looks like FA set this as the default on later boards. For boards without this, the following needs to be done.
Only need to solder in 2 parts, resistor and capacitor.
http://wiki.friendlyarm.com/wiki/index. ... y_T4_PWRON
In total there are 35 users online :: 0 registered, 0 hidden and 35 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 35 guests
