reboot issue
after reboot command:
On armbian the same
Expected that it will boot then, but nothing happening after that.
It will boot just after power off\on
Is it just on mine board or everyone has the same ?
details:
BOARD="NanoPi-Duo"
BOARD_NAME="NanoPi-Duo"
LINUXFAMILY=sun8i
BRANCH=dev
BOARD_VENDOR=FriendlyELEC
ARCH=arm
4.14.0 #83 SMP Fri Dec 8 17:44:19 CST 2017 armv7l armv7l armv7l GNU/Linux
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.3 LTS"
On armbian the same
details:
BOARD="NanoPi-Duo"
LINUXFAMILY=sun8i
BRANCH=dev
ARCH=arm
DISTRIB_ID=Ubuntu
Upgrade to Armbian and it will work:
https://dl.armbian.com/nanopiduo/archive/
I've checked, on armbian (both debian and ubuntu) latest, for now, upgraded and so on, the result is the same.
System is not going up after reboot.
Debian and Ubuntu are identical in a kernel and u-boot, where is the source of this issue.
I actually tested and it worked for me, Duo without a shield. Have you been using it with shield board? It must depend on the powering method used. There are few.
It reboots properly for me, also with a shield, powered this way: (bootlogs)
Tried all possible combinations.
If yours reboots well, becomes, mine is buggy.
Will order another one.
Thanks.
2018-01-30 09_08_35-P80130-081649 - Windows Photo Viewer.jpg (158.16 KiB) Viewed 35728 times
2018-01-30 09_08_03-P80130-082339 - Windows Photo Viewer.jpg (103.26 KiB) Viewed 35728 times
2018-01-30 09_08_19-P80130-082011 - Windows Photo Viewer.jpg (188.18 KiB) Viewed 35728 times
2018-01-30 09_07_38-P80130-082526 - Windows Photo Viewer.jpg (97.19 KiB) Viewed 35728 times
2018-01-30 09_07_15-P80130-082709 - Windows Photo Viewer.jpg (91.82 KiB) Viewed 35728 times
The log:
U-Boot SPL 2017.11-armbian (Jan 29 2018 - 07:23:16)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2017.11-armbian (Jan 29 2018 - 07:23:16 +0100) Allwinner Technology
CPU: Allwinner H3 (SUN8I 1680)
Model: FriendlyARM NanoPi DUO Air
DRAM: 512 MiB
MMC: SUNXI SD/MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
starting USB...
No controllers found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
3708 bytes read in 240 ms (14.6 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
228 bytes read in 195 ms (1000 Bytes/s)
5817526 bytes read in 833 ms (6.7 MiB/s)
6969176 bytes read in 953 ms (7 MiB/s)
Found mainline kernel configuration
32861 bytes read in 1543 ms (20.5 KiB/s)
504 bytes read in 1173 ms (0 Bytes/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
504 bytes read in 1186 ms (0 Bytes/s)
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4179 bytes read in 980 ms (3.9 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 5817462 Bytes = 5.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Loading Ramdisk to 49a73000, end 49fff476 ... OK
reserving fdt memory region: addr=43000000 size=6e000
Loading Device Tree to 49a02000, end 49a72fff ... OK
Starting kernel ...
Loading, please wait...
starting version 229
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.27.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 36287/445568 files, 289749/1900644 blocks
done.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
Welcome to Ubuntu 16.04.3 LTS!
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Reached target Encrypted Volumes.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Socket.
[ OK ] Created slice System Slice.
Mounting Debug File System...
Starting Load Kernel Modules...
Starting Set console keymap...
Starting Create list of required st... nodes for the current kernel...
Starting Nameserver information manager...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Set up automount Arbitrary Executab...ats File System Automount Point.
Mounting POSIX Message Queue File System...
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on fsck to fsckd communication Socket.
[ OK ] Started Trigger resolvconf update for networkd DNS.
[ OK ] Reached target Swap.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
Starting Restore / save the current clock...
Starting Remount Root and Kernel File Systems...
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Set console keymap.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Restore / save the current clock.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Nameserver information manager.
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
Mounting Configuration File System...
Starting Apply Kernel Variables...
[ OK ] Mounted Configuration File System.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /tmp...
[ OK ] Mounted /tmp.
[ OK ] Reached target Local File Systems.
Starting Armbian enhanced Log2Ram...
Starting Set console font and keymap...
[ OK ] Started Entropy daemon using the HAVEGE algorithm.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Found device /dev/ttyGS0.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started Armbian enhanced Log2Ram.
[ OK ] Started Set console font and keymap.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Created slice system-getty.slice.
Starting Journal Service...
Starting Load/Save RF Kill Switch Status...
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
Starting Login Service...
Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Starting LSB: Armbian gathering hardware information...
Starting LSB: Start/stop sysstat's sadc...
Starting Initializes zram swaping...
Starting Permit User Sessions...
Starting System Logging Service...
[ OK ] Reached target Network (Pre).
Starting Network Manager...
Starting Raise network interfaces...
[ OK ] Started ifup for eth0.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Permit User Sessions.
[ OK ] Started LSB: Start/stop sysstat's sadc.
[ OK ] Started System Logging Service.
[ OK ] Started Login Service.
Starting Set console scheme...
[ OK ] Started Initializes zram swaping.
[ OK ] Started Set console scheme.
[ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
Starting LSB: set CPUFreq kernel parameters...
[ OK ] Started LSB: set CPUFreq kernel parameters.
Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[ OK ] Started Raise network interfaces.
[ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[ OK ] Started Network Manager.
Starting Network Manager Wait Online...
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server...
[ OK ] Started Unattended Upgrades Shutdown.
Starting Network Manager Script Dispatcher Service...
[ OK ] Started Network Manager Script Dispatcher Service.
Starting Hostname Service...
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Hostname Service.
Starting WPA supplicant...
Starting Authenticate and Authorize Users to Run Privileged Tasks...
[ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks.
[ OK ] Started WPA supplicant.
[ OK ] Started Network Manager Wait Online.
[ OK ] Reached target Network is Online.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
Starting LSB: Advanced IEEE 802.11 management daemon...
Starting /etc/rc.local Compatibility...
Starting LSB: Start NTP daemon...
Starting LSB: disk temperature monitoring daemon...
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started LSB: disk temperature monitoring daemon.
[ OK ] Started LSB: Armbian gathering hardware information.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyGS0.
[ OK ] Reached target Login Prompts.
[ OK ] Started LSB: Start NTP daemon.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
Ubuntu 16.04.3 LTS nanopiduo ttyS0
nanopiduo login: root
Password:
Last login: Mon Jan 29 06:53:20 UTC 2018 on ttyS0
root@nanopiduo:~# reboot
[ OK ] Stopped target Gra Stopping Session 2 of user root.
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily apt upgrade and clean activities.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
Stopping User Manager for UID 0...
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Stopped Daily apt download activities.
[ OK ] Stopped target System Time Synchronized.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped target Login Prompts.
Stopping Serial Getty on ttyGS0...
Stopping LSB: Armbian gathering hardware information...
Stopping LSB: disk temperature monitoring daemon...
Stopping OpenBSD Secure Shell server...
Stopping Unattended Upgrades Shutdown...
Stopping LSB: Start NTP daemon...
Stopping Initializes zram swaping...
Stopping LSB: Set sysfs variables from /etc/sysfs.conf...
Stopping System Logging Service...
Stopping LSB: Start/stop sysstat's sadc...
Stopping Regular background program processing daemon...
Stopping LSB: Advanced IEEE 802.11 management daemon...
Stopping Getty on tty1...
Stopping Authenticate and Authorize Users to Run Privileged Tasks...
Stopping Serial Getty on ttyS0...
[ OK ] Deactivated swap /dev/zram1.
[ OK ] Deactivated swap /dev/zram0.
[ OK ] Deactivated swap /dev/zram2.
[ OK ] Stopped Regular background program processing daemon.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped OpenBSD Secure Shell server.
[ OK ] Stopped Hostname Service.
[ OK ] Stopped Authenticate and Authorize Users to Run Privileged Tasks.
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttyGS0.
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped Session 2 of user root.
[ OK ] Stopped LSB: Armbian gathering hardware information.
[ OK ] Stopped Unattended Upgrades Shutdown.
[ OK ] Stopped Initializes zram swaping.
[ OK ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Deactivated swap /dev/zram3.
[ OK ] Stopped LSB: disk temperature monitoring daemon.
[ OK ] Stopped LSB: Start NTP daemon.
[ OK ] Stopped LSB: Set sysfs variables from /etc/sysfs.conf.
[ OK ] Stopped LSB: Start/stop sysstat's sadc.
Stopping LSB: set CPUFreq kernel parameters...
[ OK ] Removed slice User Slice of root.
Stopping Login Service...
[ OK ] Removed slice system-getty.slice.
Stopping Permit User Sessions...
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped /etc/rc.local Compatibility.
[ OK ] Stopped target Network is Online.
[ OK ] Stopped Network Manager Wait Online.
[ OK ] Stopped target Network.
Stopping WPA supplicant...
Stopping Network Manager...
Stopping Raise network interfaces...
[ OK ] Stopped Login Service.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped WPA supplicant.
[ OK ] Stopped Network Manager.
[ OK ] Stopped LSB: set CPUFreq kernel parameters.
Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
Stopping D-Bus System Message Bus...
[ OK ] Stopped Raise network interfaces.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped target Remote File Systems (Pre).
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed Syslog Socket.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Stopped target System Initialization.
[ OK ] Stopped target Swap.
Stopping Armbian enhanced Log2Ram...
Stopping Entropy daemon using the HAVEGE algorithm...
[ OK ] Stopped target Encrypted Volumes.
Stopping Restore / save the current clock...
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped target Network (Pre).
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped Entropy daemon using the HAVEGE algorithm.
[ OK ] Stopped Restore / save the current clock.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Unmounted /var/log.
[ OK ] Stopped Create Volatile Files and Directories.
Stopping Load/Save Random Seed...
[ OK ] Unmounted /var/log.hdd.
[ OK ] Stopped Armbian enhanced Log2Ram.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped target Local File Systems.
Unmounting /sys/kernel/debug/tracing...
Unmounting /run/user/0...
Unmounting /tmp...
[ OK ] Unmounted /sys/kernel/debug/tracing.
[ OK ] Unmounted /run/user/0.
[ OK ] Unmounted /tmp.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Reached target Shutdown.
[ 39.758826] reboot: Restarting system
