How to power up nanopi air without otg?
Hello there,
I was wondering, is there any way to power up the NanoPi Air directly through on board wiring from a 5V3A regulator? without using the microusb or otg?
Is the microusb port onboard is only for power? or does it also have data? so that we can connect any usb peripherals through that?
Please let me know, thank you.
take a look at the upper right pins for 5v in/out and gnd at the attached picture.
there you can power the NanoPi Air via the pins :)
Also you can read additional informations in the Wiki about the NanoPi AIr:
http://wiki.friendlyarm.com/wiki/index. ... Pi_NEO_Air
got it. thanks a lot for the help. but what about the microusb? is it only power or both power and data?
BUMP
mnxford wrote:
BUMP
Power and data. On Armbian it is used as serial console.
Got it. Thanks.
In total there are 41 users online :: 0 registered, 0 hidden and 41 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 41 guests
