Shutting down system
How do you shut down system on android os?
sorry just figured it out
What was your approach?
You can't do this from a normal SDK application. You have to have system privileges and REBOOT permission which is not granted to normal apps. If you build your own source you could have a call to do this by adding your own app directly into the OS build.
