Which WiFi USB module works with Android on the NanoPi Fire3
Posted: Tue Apr 16, 2019 8:02 am
As the subject says, which one has anyone got to work on this board running Android?
http://friendlyarm.com/
<7>[ 1770.888000] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0008
<7>[ 1770.888000] hub 1-1:1.0: port 3, status 0101, change 0001, 12 Mb/s
<7>[ 1771.016000] hub 1-1:1.0: debounce: port 3: total 100ms stable 100ms status 0x101
<6>[ 1771.088000] usb 1-1.3: new high-speed USB device number 4 using nxp-ehci
<7>[ 1771.104000] hub 1-1:1.0: port 3 not reset yet, waiting 10ms
<7>[ 1771.200000] usb 1-1.3: default language 0x0409
<7>[ 1771.200000] usb 1-1.3: udev 4, busnum 1, minor = 3
<6>[ 1771.200000] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8176
<6>[ 1771.200000] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 1771.208000] usb 1-1.3: Manufacturer: Realtek
<6>[ 1771.212000] usb 1-1.3: SerialNumber: 00e04c000001
<7>[ 1771.220000] usb 1-1.3: usb_probe_device
<7>[ 1771.220000] usb 1-1.3: configuration #1 chosen from 1 choice
<7>[ 1771.220000] usb 1-1.3: adding 1-1.3:1.0 (config #1, interface 0)
<7>[ 1771.220000] rtl8192cu 1-1.3:1.0: usb_probe_interface
<7>[ 1771.220000] rtl8192cu 1-1.3:1.0: usb_probe_interface - got id
<6>[ 1771.220000] rtl8192cu: Chip version 0x10
<6>[ 1771.320000] rtl8192cu: MAC address: e8:4e:06:1f:f6:5c
<6>[ 1771.320000] rtl8192cu: Board Type 0
<6>[ 1771.324000] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
<6>[ 1771.328000] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
<7>[ 1771.336000] drivers/usb/core/inode.c: creating file '004'
<7>[ 1771.336000] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0008
<3>[ 1771.336000] rtlwifi: Firmware rtlwifi/rtl8192cufw.bin not availableCode: Select all
adb push rtl8192cufw.bin /system/vendor/firmware/rtlwifi/rtl8192cufw.binCode: Select all
<7>[ 241.288000] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0008
<7>[ 241.288000] hub 1-1:1.0: port 3, status 0101, change 0001, 12 Mb/s
<7>[ 241.416000] hub 1-1:1.0: debounce: port 3: total 100ms stable 100ms status 0x101
<6>[ 241.488000] usb 1-1.3: new high-speed USB device number 4 using nxp-ehci
<7>[ 241.504000] hub 1-1:1.0: port 3 not reset yet, waiting 10ms
<7>[ 241.596000] usb 1-1.3: default language 0x0409
<7>[ 241.596000] usb 1-1.3: udev 4, busnum 1, minor = 3
<6>[ 241.596000] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8176
<6>[ 241.596000] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 241.604000] usb 1-1.3: Manufacturer: Realtek
<6>[ 241.608000] usb 1-1.3: SerialNumber: 00e04c000001
<7>[ 241.616000] usb 1-1.3: usb_probe_device
<7>[ 241.616000] usb 1-1.3: configuration #1 chosen from 1 choice
<7>[ 241.616000] usb 1-1.3: adding 1-1.3:1.0 (config #1, interface 0)
<7>[ 241.616000] rtl8192cu 1-1.3:1.0: usb_probe_interface
<7>[ 241.616000] rtl8192cu 1-1.3:1.0: usb_probe_interface - got id
<6>[ 241.616000] rtl8192cu: Chip version 0x10
<6>[ 241.716000] rtl8192cu: MAC address: e8:4e:06:1f:f6:5c
<6>[ 241.716000] rtl8192cu: Board Type 0
<6>[ 241.720000] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
<6>[ 241.724000] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
<7>[ 241.732000] drivers/usb/core/inode.c: creating file '004'
<7>[ 241.732000] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0008
<7>[ 241.732000] ieee80211 phy1: Selected rate control algorithm 'rtl_rc'
<6>[ 241.736000] rtlwifi: wireless switch is on
<7>[ 251.680000] dhd_module_init: in
<7>[ 251.680000] ======== bcm_wlan_set_plat_data ========
<7>[ 251.680000] host_oob_irq: 187
<7>[ 251.680000] host_oob_irq_flags = 414
<7>[ 251.680000] dhd_wifi_platform_load: Enter
<7>[ 251.680000] Power-up adapter 'DHD generic adapter'
<7>[ 251.680000] wifi_platform_set_power = 1
<7>[ 251.680000] ======== PULL WL_REG_ON HIGH! ========
<7>[ 251.680000] wifi_pm: bcmdhd: 1
<7>[ 252.000000] wifi_platform_bus_enumerate device present 1
<3>[ 253.036000] dw_mmc dw_mmc.1: Data0: Never released by cmd52
<7>[ 253.200000] failed to power up DHD generic adapter, 1 retry left
<7>[ 253.228000] wifi_platform_set_power = 0
<7>[ 253.228000] ======== PULL WL_REG_ON LOW! ========
<7>[ 253.228000] wifi_pm: bcmdhd: 0
<7>[ 253.340000] wifi_platform_bus_enumerate device present 0
<3>[ 254.040000] dw_mmc dw_mmc.1: Data0: Never released by cmd52
<3>[ 255.048000] dw_mmc dw_mmc.1: Data0: Never released by cmd0
<3>[ 256.052000] dw_mmc dw_mmc.1: Data0: Never released by cmd8
<3>[ 257.060000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 258.068000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 259.072000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 260.076000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 261.080000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 262.088000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 263.092000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 264.096000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 265.100000] dw_mmc dw_mmc.1: Data0: Never released by cmd1
<7>[ 265.100000] failed to power up DHD generic adapter, max retry reached**
<7>[ 265.100000] unregister wifi platform drivers
<7>[ 265.100000] wifi_platform_bus_enumerate device present 0
<7>[ 265.100000] dhd_module_init: Failed to load the driver, try cnt 1
<7>[ 265.100000] ======== bcm_wlan_set_plat_data ========
<7>[ 265.100000] host_oob_irq: 187
<7>[ 265.100000] host_oob_irq_flags = 414
<7>[ 265.100000] dhd_wifi_platform_load: Enter
<7>[ 265.100000] Power-up adapter 'DHD generic adapter'
<7>[ 265.100000] wifi_platform_set_power = 1
<7>[ 265.100000] ======== PULL WL_REG_ON HIGH! ========
<7>[ 265.100000] wifi_pm: bcmdhd: 1
<7>[ 265.420000] wifi_platform_bus_enumerate device present 1
<3>[ 266.456000] dw_mmc dw_mmc.1: Data0: Never released by cmd52
<7>[ 266.620000] failed to power up DHD generic adapter, 1 retry left
<7>[ 266.648000] wifi_platform_set_power = 0
<7>[ 266.648000] ======== PULL WL_REG_ON LOW! ========
<7>[ 266.648000] wifi_pm: bcmdhd: 0
<7>[ 266.764000] wifi_platform_bus_enumerate device present 0
<3>[ 267.464000] dw_mmc dw_mmc.1: Data0: Never released by cmd52
<3>[ 268.476000] dw_mmc dw_mmc.1: Data0: Never released by cmd0
<3>[ 269.484000] dw_mmc dw_mmc.1: Data0: Never released by cmd8
<3>[ 270.492000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 271.496000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 272.500000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 273.504000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
<3>[ 274.512000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 275.520000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 276.528000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 277.532000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
<3>[ 278.540000] dw_mmc dw_mmc.1: Data0: Never released by cmd1
<7>[ 278.540000] failed to power up DHD generic adapter, max retry reached**
<7>[ 278.540000] unregister wifi platform drivers
<7>[ 278.540000] wifi_platform_bus_enumerate device present 0
<7>[ 278.540000] dhd_module_init: Failed to load the driver, try cnt 0
<7>[ 278.540000] dhd_module_init: Failed to load driver max retry reached**
<7>[ 278.540000] dhd_module_init: Exit err=-19
[ 43.188000] dw_mmc dw_mmc.1: Hardware locked write error
[ 43.204000] dw_mmc dw_mmc.1: Hardware locked write error
[ 44.228000] dw_mmc dw_mmc.1: Data0: Never released by cmd52
[ 45.232000] dw_mmc dw_mmc.1: Data0: Never released by cmd52
[ 45.232000] dw_mmc dw_mmc.1: Hardware locked write error
[ 46.240000] dw_mmc dw_mmc.1: Data0: Never released by cmd0
[ 46.240000] dw_mmc dw_mmc.1: Hardware locked write error
[ 47.248000] dw_mmc dw_mmc.1: Data0: Never released by cmd8
[ 48.256000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
[ 49.260000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
[ 50.264000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
[ 51.272000] dw_mmc dw_mmc.1: Data0: Never released by cmd5
[ 52.276000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
[ 53.280000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
[ 54.288000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
[ 55.292000] dw_mmc dw_mmc.1: Data0: Never released by cmd55
[ 55.292000] dw_mmc dw_mmc.1: Hardware locked write errorDesignerDave wrote:
Truly a disappoint as the board is killer otherwise.
