Errors during u-boot compile
Posted: Sat Jun 09, 2018 5:01 pm
by Oleg
Hi! I would like to compile u-boot but get following errors. Could you please give me a clue how to solve them? Thank you!
ArchLinux Other Linux 4.x or later kernel 64-bit-2018-06-02-21-26-41.png (20.62 KiB) Viewed 42512 times
Re: Errors during u-boot compile
Posted: Sat Jun 16, 2018 12:50 am
by Oleg
I got normal log of my build, hope it will help to figure out what the problem I have.
[fire3@vmware u-boot]$ make CROSS_COMPILE=aarch64-linux-
  CHK     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CHK     include/generated/generic-asm-offsets.h
  CHK     include/generated/asm-offsets.h
  HOSTCC  tools/mkenvimage.o
  HOSTLD  tools/mkenvimage
  HOSTCC  tools/aisimage.o
In file included from tools/../include/libfdt.h:54,
                 from tools/fdt_host.h:11,
                 from tools/imagetool.h:24,
                 from tools/aisimage.c:8:
/usr/include/libfdt_env.h:70:30: error: conflicting types for ‘fdt64_t’
 typedef uint64_t FDT_BITWISE fdt64_t;
In file included from <command-line>:
././include/libfdt_env.h:19:16: note: previous declaration of ‘fdt64_t’ was here
 typedef __be64 fdt64_t;
In file included from ././include/libfdt_env.h:12,
/usr/include/libfdt_env.h:90:24: error: expected ‘)’ before ‘x’
 static inline uint32_t fdt32_to_cpu(fdt32_t x)
././include/compiler.h:66:9: error: expected ‘)’ before ‘&’ token
  ((((x) & 0xff000000) >> 24) | \
././include/compiler.h:66:23: error: expected ‘)’ before ‘>>’ token
././include/compiler.h:66:30: error: expected ‘)’ before ‘|’ token
/usr/include/libfdt_env.h:94:23: error: expected ‘)’ before ‘x’
 static inline fdt32_t cpu_to_fdt32(uint32_t x)
/usr/include/libfdt_env.h:99:24: error: expected ‘)’ before ‘x’
 static inline uint64_t fdt64_to_cpu(fdt64_t x)
././include/compiler.h:71:9: error: expected ‘)’ before ‘&’ token
  ((((x) & 0xff00000000000000##sfx) >> 56) | \
././include/compiler.h:71:36: error: expected ‘)’ before ‘>>’ token
././include/compiler.h:71:43: error: expected ‘)’ before ‘|’ token
/usr/include/libfdt_env.h:103:23: error: expected ‘)’ before ‘x’
 static inline fdt64_t cpu_to_fdt64(uint64_t x)
In file included from include/image.h:50,
                 from tools/aisimage.c:10:
/usr/include/libfdt.h:149:21: error: redefinition of ‘fdt_offset_ptr_w’
 static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen)
In file included from tools/fdt_host.h:11,
tools/../include/libfdt.h:136:21: note: previous definition of ‘fdt_offset_ptr_w’ was here
/usr/include/libfdt.h:234:1: error: redefinition of ‘fdt_set_magic’
 fdt_set_hdr_(magic);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_magic’ was here
  static inline void fdt_set_##name(void *fdt, uint32_t val) \
tools/../include/libfdt.h:219:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(magic);
/usr/include/libfdt.h:235:1: error: redefinition of ‘fdt_set_totalsize’
 fdt_set_hdr_(totalsize);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_totalsize’ was here
tools/../include/libfdt.h:220:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(totalsize);
/usr/include/libfdt.h:236:1: error: redefinition of ‘fdt_set_off_dt_struct’
 fdt_set_hdr_(off_dt_struct);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_off_dt_struct’ was here
tools/../include/libfdt.h:221:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(off_dt_struct);
/usr/include/libfdt.h:237:1: error: redefinition of ‘fdt_set_off_dt_strings’
 fdt_set_hdr_(off_dt_strings);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_off_dt_strings’ was here
tools/../include/libfdt.h:222:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(off_dt_strings);
/usr/include/libfdt.h:238:1: error: redefinition of ‘fdt_set_off_mem_rsvmap’
 fdt_set_hdr_(off_mem_rsvmap);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_off_mem_rsvmap’ was here
tools/../include/libfdt.h:223:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(off_mem_rsvmap);
/usr/include/libfdt.h:239:1: error: redefinition of ‘fdt_set_version’
 fdt_set_hdr_(version);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_version’ was here
tools/../include/libfdt.h:224:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(version);
/usr/include/libfdt.h:240:1: error: redefinition of ‘fdt_set_last_comp_versio’
 fdt_set_hdr_(last_comp_version);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_last_comp_version’ was here
tools/../include/libfdt.h:225:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(last_comp_version);
/usr/include/libfdt.h:241:1: error: redefinition of ‘fdt_set_boot_cpuid_phys’
 fdt_set_hdr_(boot_cpuid_phys);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_boot_cpuid_phys’ was here
tools/../include/libfdt.h:226:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(boot_cpuid_phys);
/usr/include/libfdt.h:242:1: error: redefinition of ‘fdt_set_size_dt_strings’
 fdt_set_hdr_(size_dt_strings);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_size_dt_strings’ was here
tools/../include/libfdt.h:227:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(size_dt_strings);
/usr/include/libfdt.h:243:1: error: redefinition of ‘fdt_set_size_dt_struct’
 fdt_set_hdr_(size_dt_struct);
tools/../include/libfdt.h:214:21: note: previous definition of ‘fdt_set_size_dt_struct’ was here
tools/../include/libfdt.h:228:1: note: in expansion of macro ‘__fdt_set_hdr’
 __fdt_set_hdr(size_dt_struct);
/usr/include/libfdt.h:595:36: error: redefinition of ‘fdt_get_property_w’
 static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset,
tools/../include/libfdt.h:516:36: note: previous definition of ‘fdt_get_property_w’ was here
/usr/include/libfdt.h:692:21: error: redefinition of ‘fdt_getprop_w’
 static inline void *fdt_getprop_w(void *fdt, int nodeoffset,
tools/../include/libfdt.h:601:21: note: previous definition of ‘fdt_getprop_w’ was here
/usr/include/libfdt.h:1190:19: error: redefinition of ‘fdt_setprop_inplace_u3’
 static inline int fdt_setprop_inplace_u32(void *fdt, int nodeoffset,
tools/../include/libfdt.h:1057:19: note: previous definition of ‘fdt_setprop_inplace_u32’ was here
/usr/include/libfdt.h:1225:19: error: redefinition of ‘fdt_setprop_inplace_u6’
 static inline int fdt_setprop_inplace_u64(void *fdt, int nodeoffset,
tools/../include/libfdt.h:1092:19: note: previous definition of ‘fdt_setprop_inplace_u64’ was here
/usr/include/libfdt.h:1237:19: error: redefinition of ‘fdt_setprop_inplace_cell’
 static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset,
tools/../include/libfdt.h:1104:19: note: previous definition of ‘fdt_setprop_inplace_cell’ was here
/usr/include/libfdt.h:1303:19: error: redefinition of ‘fdt_property_u32’
 static inline int fdt_property_u32(void *fdt, const char *name, uint32_t val)
tools/../include/libfdt.h:1170:19: note: previous definition of ‘fdt_property_u32’ was here
/usr/include/libfdt.h:1308:19: error: redefinition of ‘fdt_property_u64’
 static inline int fdt_property_u64(void *fdt, const char *name, uint64_t val)
tools/../include/libfdt.h:1175:19: note: previous definition of ‘fdt_property_u64’ was here
/usr/include/libfdt.h:1313:19: error: redefinition of ‘fdt_property_cell’
 static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val)
tools/../include/libfdt.h:1180:19: note: previous definition of ‘fdt_property_cell’ was here
/usr/include/libfdt.h:1510:19: error: redefinition of ‘fdt_setprop_u32’
 static inline int fdt_setprop_u32(void *fdt, int nodeoffset, const char *name,
tools/../include/libfdt.h:1330:19: note: previous definition of ‘fdt_setprop_u32’ was here
/usr/include/libfdt.h:1545:19: error: redefinition of ‘fdt_setprop_u64’
 static inline int fdt_setprop_u64(void *fdt, int nodeoffset, const char *name,
tools/../include/libfdt.h:1365:19: note: previous definition of ‘fdt_setprop_u64’ was here
/usr/include/libfdt.h:1557:19: error: redefinition of ‘fdt_setprop_cell’
 static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name,
tools/../include/libfdt.h:1377:19: note: previous definition of ‘fdt_setprop_cell’ was here
/usr/include/libfdt.h:1682:19: error: redefinition of ‘fdt_appendprop_u32’
 static inline int fdt_appendprop_u32(void *fdt, int nodeoffset,
tools/../include/libfdt.h:1472:19: note: previous definition of ‘fdt_appendprop_u32’ was here
/usr/include/libfdt.h:1717:19: error: redefinition of ‘fdt_appendprop_u64’
 static inline int fdt_appendprop_u64(void *fdt, int nodeoffset,
tools/../include/libfdt.h:1507:19: note: previous definition of ‘fdt_appendprop_u64’ was here
/usr/include/libfdt.h:1729:19: error: redefinition of ‘fdt_appendprop_cell’
 static inline int fdt_appendprop_cell(void *fdt, int nodeoffset,
tools/../include/libfdt.h:1519:19: note: previous definition of ‘fdt_appendprop_cell’ was here
make[1]: *** [scripts/Makefile.host:108: tools/aisimage.o] Error 1
make: *** [Makefile:1249: tools] Error 2
Posted: Sun Jul 08, 2018 2:18 am
by Oleg
I send more time tracking this errors. My original build environment was Arch Linux on VMware virtual machine. I setted up Ubuntu on VMware virtual machine and got everything compiled just fine.
The only difference I see between these two setups is that Arch Linus has device-tree-compiler executable and C header files right in one package (https://www.archlinux.org/packages/comm ... 86_64/dtc/) while Ubuntu separates them as device-tree-compiler (https://packages.ubuntu.com/bionic/amd6 ... r/filelist) and libfdt-dev (https://packages.ubuntu.com/bionic/amd6 ... v/filelist), the last one maybe is not installed, need to check.
Maybe that lid to conflict of inclusion of two different definitions for fdt64_t:
one comes from u-boot internal definition and the other one comes from Arch Linux /usr/include/libfdt_env.h.
Same time Makefile supposed to handle the presence of both definitions, but something goes wrong.
I would quite appreciate any hints on how to get u-boot to compile on Arch Linux as I am more familiar with this environment and my goal is to get Arch Linux running on Fire3.
Posted: Fri May 17, 2019 7:01 am
by v8dave
Which kernel are you trying to compile? 3.4 or 4.4?
3.4 is 32 bit and 4.4 is 64 bit. You need to be using the correct compiler. I found this out myself when trying to use the aarch64 with the 3.4 kernel. It doesn't build and spit our heaps of errors.
Posted: Fri May 17, 2019 7:28 am
by igorp
Or you use Armbian build engine which does that (and much more) - pick the right compiler - for your. It can save you a lot time.
Posted: Fri May 17, 2019 7:41 am
by v8dave
On the subject of compilers, is there an easy way to build the kernel with an IDE such as Eclipse? I'd like a way to edit and navigate variables across the build. It's tedious trying to search each time to find where a variable is declared.
Posted: Mon Sep 09, 2019 6:58 am
by AbhinavRana
While I am building custom U-Boot for our board, I am getting fatal error "linux/compiler-gcc5.h: No such file or directory
compilation terminated."
Uboot version : u-boot-2013.01.01-psp06.00.00.00
Toolchain: gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf
Command :make O=am335x CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm am335x_evm
How to resolve the problem ?
