T3GPU
Its always hard to get info on Samsung chips GPU, but can someone tell us what is in the T3, it appears to be a single core Mali 400
I must admit to being a little disappointed, all that CPU power but a rather limp and old Graphic system, If it had a multi core or more up-to-date Mail chip it could be a seriously powerful graphics board.
Yes T3's GPU is Mali 400
Thanks for that, is it single core?
MP1?
MP1?
Features
SoC: Samsung S5P6818 Octa-Core Cortex-A53, 400M Hz - 1.4G Hz
Power Management Unit: AXP228 PMU, it supports software power-off and wake-up.
System Memory: 1GB/2GB 32bit DDR3 RAM
Storage: 1 x SD Card Socket
Ethernet: Gbit Ethernet(RTL8211E)
WiFi: 802.11b/g/n
Bluetooth: 4.0 dual mode
Antenna: Porcelain Antenna IPX Interface
eMMC: 8GB
Video Input: DVP Camera/MIPI-CSI (two camera interfaces)
Video Output: HDMI Type-A / LVDS / Parallel RGB-LCD / MIPI-DSI (four video output interfaces)
Audio: 3.5 mm audio jack / via HDMI
Microphone: onboard Microphone
USB Host: 4 x USB 2.0 Host, two type A ports and two 2.54 mm pitch pin-headers
MicroUSB: 1 x MicroUSB 2.0 Client, Type A
LCD Interface: 0.5mm pitch 45 pin FPC seat, full color RGB 8-8-8
HDMI: 1.4A Type A, 1080P
DVP Camera: 0.5mm pitch 24 pin FPC seat
GPIO: 2.54 mm pitch 30 pin-header
Serial Debug Port: 2.54mm pitch 4-pin-header
User Key: K1 (power), Reset
LED: 1 x power LED and 2 x GPIO LED
Other Resources: CPU’s internal TMU
RTC Battery: RTC Battery Seat
Heat Sink: 1 x Heat Sink with mounting holes
Power: DC 5V/2A
PCB: Six Layer
Dimension: 100 mm x 60 mm
OS/Software: uboot, Android and Debian
:D that didn't actually answer my question :D
Which is specifically about the GPU which is a Mali 400MP
but is it MP1 or MP2 or more?
I suspect its just an MP1 which is a shame. The 8 cores make this a very powerful CPU, but a single core GPU means it lags far behind the Odroid XU4 with its 6 core Mali T628 when it comes to graphics performance.
It is MP2
Thank you that is useful.
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 22 guests
