Dual Display Possible on Mini6410?
I want to connect a monitor to the Mini6410 through LCD2 connector so that i can have dual display(LCD3 connector is already used for connection to another small screen). I tried to connect a monitor through LCD2 connector(with an LCD to VGA converter) but the monitor just shows a white screen, i.e. it didn't work.
Is dual display possible (or to extend monitor)on Mini6410? If yes, can you explain how?
Thanks in advance people,
:D
I have exactly the same issue. Any updates?
