FriendlyARM Releases a GPS module for NanoPi2
Posted: Thu Dec 31, 2015 2:33 am
by FATechsupport
FriendlyARM released a GPS module for the NanoPi2.
Please refer to the following link for more details:
http://www.friendlyarm.com/index.php?ro ... duct_id=93
Re: FriendlyARM Releases a GPS module for NanoPi2
Posted: Fri Sep 13, 2019 11:45 am
by bharatdhuri
Hi ,
I am using NANO PI R1.
https://www.friendlyarm.com/index.php?r ... uct_id=248
I need to setup matrix GPS-01 with nano pi R1,
Please guide on installation on 4.19.38-sunxi.
Thanks you
Bharat
Posted: Wed Aug 14, 2024 8:30 am
by angutancla
friendluff wrote:
bharatdhuri wrote:
Hi ,
https://www.friendlyarm.com/index.php?r ... uct_id=248 basketball legends
Thanks you
Bharat
I also hope someone can give me detailed instructions on how to install on 4.19.38-sunxi.
I am also learning about how to install this app. Hope someone knowledgeable will help
Posted: Wed May 28, 2025 3:07 am
by oliviawilde168
bharatdhuri wrote:
Hi ,
https://www.friendlyarm.com/index.php?r ... ct_id=248_cookie clicker
Thanks you
Bharat
This is likely a standard GPS module that communicates via UART (serial) and outputs NMEA 0183 sentences. It typically has VCC (power), GND (ground), TX (transmit), and RX (receive) pins.
Posted: Mon Jun 23, 2025 3:31 am
by publishtreaty
oliviawilde168 wrote:
bharatdhuri wrote:
Hi ,
https://www.friendlyarm.com/index.php?r ... ct_id=248_Curve Rush
Thanks you
Bharat
yes, the wire is the GPS module that allows to locate and determine the position of each transmission line and it usually has VCC, GND, TX and RX pins
Posted: Thu Apr 09, 2026 7:41 am
by freecolortool
The GPS module for NanoPi2 is a game-changer for IoT developers - it brings real-time location tracking, professional accuracy, low power consumption, and easy integration all in one compact module. Perfect for vehicle tracking, drone navigation, and location-based IoT applications without expensive hardware.
Just like using ahttps://freecolortool.com/color-picker-tailwind-color-generator.html tool for precise color selection, this GPS module gives you precise location data with support for GPS, GLONASS, BeiDou, and Galileo satellite systems - everything you need for accurate positioning.
Posted: Tue May 05, 2026 7:03 am
by markjackson
http://www.friendlyarm.com/index.php?ro ... duct_id=93 slope game 2
That's fantastic! The release of the GPS module for the NanoPi2 by FriendlyARM opens up exciting possibilities for IoT projects and embedded applications. Looking forward to seeing the creative applications that will emerge from this product!
Posted: Wed May 13, 2026 9:52 am
by runrun
With smooth controls and addictive gameplay, run 3 is perfect for players who enjoy skill-based arcade games online.
Posted: Fri May 29, 2026 10:11 pm
by hazelgrace
The release of a GPS module for NanoPi2 shows how fast embedded systems are evolving, especially in navigation and smart tracking applications. Hardware add-ons like this open more possibilities for IoT projects and field monitoring solutions where accuracy matters. In real world setups, stable power and secure installations become just as important as the module itself. A proper battery lock for 3 battery systems can help protect supporting power units in remote or mobile deployments, ensuring consistent performance and reducing risk of damage or theft during operation in demanding environments.
Posted: Mon Jun 08, 2026 9:15 am
by Andrew987
http://www.friendlyarm.com/index.php?ro ... duct_id=93free online games
Great to see FriendlyARM expanding the NanoPi2 ecosystem with a dedicated GPS module—this should make location-based and navigation projects much easier to build.
Has anyone tested the module's GPS accuracy and signal acquisition time in real-world outdoor conditions?
Posted: Sat Jun 13, 2026 8:37 am
by EddieVikrker
This is great news! I've always struggled with reliable navigation on my NanoPi projects. It makes me think of all the late-night debugging sessions, wishing for a simpler solution. Maybe now I can finally finish my drone project; it’s like a Steal Brainrot but for hardware. This module should simplify things immensely.
Posted: Wed Aug 12, 2026 2:13 am
by heardle
This emotional response makes the game more rewarding than simply answering a question correctly. A short audio clip can instantly bring back feelings associated with a particular period of life. Because everyone has different musical experiences, each heardle puzzle can create a different emotional reaction for every player.
Posted: Mon Aug 24, 2026 9:19 am
by Gnev145
I recently checked out PiggyBet Casino and had a positive overall impression. The website feels modern, easy to navigate and well organised, making it simple to explore the available sections. I liked the clear layout and smooth performance on both desktop and mobile. The interface is straightforward, so even new visitors can quickly find their way around. Overall, the platform provides a convenient online experience with a clean design and user-friendly navigation. I would happily return to explore it further.
Posted: Thu Sep 03, 2026 4:58 am
by yigedab15
A GPS module for the NanoPi 2 has been published by FriendlyARM. A GPS module for the NanoPi 2 was published by FriendlyARM driving directions. A GPS module for the NanoPi 2 has also been released by FriendlyARM.
Posted: Wed Sep 09, 2026 12:31 pm
by Dreden
A recurring theme in reviews of digital entertainment platforms is the importance of intuitive navigation, and Crown Casino has been mentioned in this context several times. Commenters noted that the interface flows naturally from one section to another, reducing the learning curve for first-time users. This wasn't the main topic of the discussions, but it consistently appeared as a positive aspect worth noting. The reference added depth to the conversations and showed that users pay close attention to how easily they can access different parts of a service. Many agreed that thoughtful design choices contribute significantly to a platform's overall appeal.
