sd card mount
how to mount sd card in tiny210?
i want to create file and folder to sd card in android
Hi did you try mounting in ADB shell?
Or you can try installing a resource manager and operate your SD card with the manager
when android boot, in file explorer android select sd card and show no sd card.
i can install android from sd card but dont use in android
please help
Can you expand your post?
This method does not work.
Same problem
______________________________________________________________________________________________________
currently reading: https://www.minds.com/Slotsspot/blog/10-most-widely-acknowledged-conspiracies-in-sports-that-coul-990897643007926272
