M2A wakeup
how to wake up M2A from suspend mode ?
PWR button don't wakeup my M2A. :roll:
Is this hardware problem or FA software/kernel don't support wakeup?
M2A has AXP228 chip, support software shutdown and wake up sleep.
What system do you use?
i'm using S5P4418-ubuntu-core-qt4-sd4g-20170414 and tested S5P4418-debian-sd4g-20170414 too.
I have installed pm-utils and used pm-suspend command. Maybe i do something wrong and should put M2A into
suspend to ram mode in another way ? How ?
I want to use PWRKEY, internal RTC (battery is connected) or/and Alive PIN to wake up this board.
Thanks,
i have made some tests and i must say suspend and wake-up don't work correctly.
"suspend_valid: not supported state"
Tested on S5P4418-ubuntu-core-qt4-sd4g-20170414
M2A+X710 LCD:
the board is not going into suspend mode it hangs. Wake-up don't work.
red led on
blue led off
After PWR button press (wake-up): nothing change
Edit:
Sometimes is going the board into suspend mode. But wake-up hangs.
red led on
blue led off
system is not waking up
M2A+HDMI LCD:
the board is going into suspend mode but wake-up hangs.
red led off
blue led off
red led on
blue led off
system is not waking up.
It seems like kernel or some drivers are not right configured for suspend and wake-up.
